- Jan 4, 2012
- 12
- 0
- 66
I have a PC that keeps shutting itself off. It doesn't reboot, it shuts down as if someone had unplugged the cord. Once it happens, pushing the power button doesn't do anything for several minutes. After the wait, I can try to boot again.
Sometimes it happens within seconds of boot, sometimes when Windows hits the desktop. Sometimes it sits there for an hour, then shuts down as soon as I start using it. Other times it works all day long.
It has plenty of ventilation. All of the fans are working, and work up and through the crash. I've sat there and watched the CPU fan keep spinning while it shuts down.
It isn't lack of power. The PSU is a 750 watt, which is overkill for the hardware.
It can't be heat, as the system is clean and it frequently happens on the first boot of the day before it even starts loading Windows.
I've swapped out the RAM, running different sticks from different manufacturers in different slots.
I've tried swapping out the PSU for a 400 watt I had sitting around.
I've tried removing extraneous cards (sound, network.)
I've tried removing all drives except for the system drive.
I've swapped out IDE/SATA cables.
I'm at a loss for what else to try.
