- May 4, 2019
- 1
- 0
- 6
My front wheel bearings went out first the one the left side went out it tore up the hub an several other parts I had the left front end replaced all the way to the axle on the independent suspension got the truck back still heard a grinding sure enough it was the right side so I had it replaced before it damaged anything else this time I jus got the truck back it's still making a grinding noise when I accelerate I've made sure the metal plate behind the rotors are not rubbing the rotors none of the wheels have play in them but when I jacked the truck up the front right tire was sticking was hard to make it turn backwards but it will spin forwards very easy making a clicking noise as it spins. I've power washed the whole bottom of the truck all around the wheels I dont see any pebble or anything stuck in there
