Need help fast: help with cat5 wiring
Brutuskend
26,558
4
It depends on if your running it into a hub or straight from one computer to another computer.
CraigRT
31,440
this is the way i do CAT5 straight through:
1greenwhite 2green 3orangewhite 4blue 5bluewhite 6orange 7brownwhite 8brown
follow that at both ends and your straight through cable will be done.
Narse
Moderator<br>Computer Help
Moderator
Mar 14, 2000
3,826
Cat5 spec calls for this color code for a straight cable
orangewhite orange greenwhite blue bluewhite green brownwhite brown
For a cross over make one end with the above pinout and the other end like this
greenwhite green orangewhite brownwhite brown orange blue bluewhite
That will work for 100baseTX
