What BIOS version do you have? I don't see an option for SATA RAID/AHCI mode. I am using BIOS FDb. Make sure that the SSD is attached to one of the blue SATA ports 0-3, preferably port 0 if it is your boot drive. In the BIOS check the entry ICH SATA Control Mode under Integrated Peripherals. This is for the blue SATA ports controlled by the Intel ICH10R. Options are IDE, AHCI, RAID. You can set to IDE or AHCI for your use. I am not familiar with SSD drives but I think I read that they benefit slightly from running in AHCI mode. Vista and 7 will load AHCI drivers for you. With XP you must use the F6 method to load the drivers during install. Set SATA port 0-3 Native Mode to Enabled. Onboard SATA/IDE device is for the white ports controlled by the Gigabyte (Jmicron) chip. I would not use these for your SSD. They are OK for opticals if you run out of blue ports. If you are not using them you can set to Disabled. Otherwise set to IDE mode.
Edit: From the Intel site:
"Do Intel SSDs need special driver support?
No. The standard drivers for any HDD will support Intel SSDs as drop-in components, such as those bundled with Windows*. However, for best performance, a driver that supports SATA Native Command Queuing (NCQ) is recommended, such as the Intel® Matrix Storage Manager (IMSM) driver from Intel.
Note: The Windows Vista* driver has a bug which does not allow NCQ on Intel SSDs. For Vista*, only IMSM is recommended. An update will be provided when this issue has been resolved."
So yes, you should run in AHCI mode which supports NCQ. Apparently in Vista you will need to load the driver too due to the aforementioned bug.
