Need help dual booting WinME and Mandrake 7.0
Quaker
38
I have a 40 gig harddrive that i was wanting basically split in half give 20 gigs to WinME and 20 gigs to Mandrake... Is this possible? And if so what do i need to used to be able to do this? All help greatly appreciated.. THX
FOBSIDE
2,178
dang...3 posts. 20 gigs is a lot for one partition. you might want to reconsider the size of the partition. install win me first. when you install mandrake it should set up the dual boot when you install.
Quaker
38
ok i'll try thx.... yeah i lagged alittle bit and got impatient so i ended up w/3 posts.. sorry
