Hey AnandTech,
Long time reading finally had to come and ask for help on this issue.
I have been dealing with a very annoying PC hang ever since I had this machine put together 2ish years ago. This may be a little long winded but I have done a lot of trouble shooting over the time and will provide what I have come up with, it's just come to the point where I need a new pair of eyes to look on the situation.
First off specs:
Motherboard: AsusStriker II Formula, Nforce 780i (latest BIOS)
CPU: Intel QX6850 (Kentsfield)
GPU: SLI EVGA 8800gtx's
PSU: 1000W Cooler Master
RAM: 8 gigs OCZ Vista Upgrade pc2 6400
Sound Card: Auzen Prelude 7.1
Case: Antec 900
CPU Cooler: Zalman CNPS9700
OS: Windows 7 64 bit
Nothing is overclocked atm, I have enough issues as is.
Symptoms:
Ok so when doing a combination of heavy gaming and listening to mp3's(it always seems to be a combination of the 2) the system will hang, the screen stays on the frame it was at, and the speakers give a high pitched ringing sound. Nothing responds and I am forced to hard reset. Now sometimes I can go multiple days with no issues others it happens 2-3 times a night.
What I have Tried:
Okay so I have monitored temps a lot and I don't think this is a case of overheating, I have a screen shot of temps of everything from a few hour gaming session that I captured with Everest. (also have voltages and such if needed)
Power Supply:
I have a Zalman fan controller on the front of my case that monitors wattage and I have never seen it pull more than 600 watts so that should not be an issue.
RAM:
8 gigs of OCZ Vista Upgrade running at 1:1 (333.3MHz) no overclocking running at 667mhz. I have run memtest86+ and windows memory diagnostic and found no issues. If you need screen shots from CPU-z I can do that.
GPU / Sound Card:
I have read and seen that lots of people have had issues with Nvidia cards/Nforce/ and x-fi sound cards, could this be a possibility? Also I know it should not be an issue and windows now a days but both 8800's and the prelude share IRQ 16.
Other Notes:
I am actually on my 3rd motherboard in this machine, the first two were also Asus (p5n32-e sli and p5n32-e sli+) and I had this issue on both of those boards as well.
Started with 4 gigs in the machine and had the issue as well.
I have had this issue in XP, Vista and Windows 7
Also I rarely have SLI enabled as I prefer to use my 3 monitors.
So I guess I am asking should I be looking to:
~Add more cooling?
~Try new RAM?
~Try taking out the Auzen card to see if it is the issue?
~Is it a GPU issue?
~ Or is there something here I am completely missing that could be the issue?
Any thoughts comments or input is greatly appreciated as I am sick of dealing with this issue. If you need any other numbers screen shots or info just let me know.
~Thanks again
First off specs:
Case: Antec 900
Symptoms:
What I have Tried:
Power Supply:
RAM:
GPU / Sound Card:
Other Notes:
~Add more cooling?
~Try new RAM?
~Is it a GPU issue?
~Thanks again
