Need Help diagnosing a BSOD
Gautama2
1,461
[*]Full description of the problem and symptoms
I've got a very bland recurring BSOD- IRQ not less or equal, Stop 0x0000000a, no driver listed.. It seems to occur randomly in both high load and low load situations. I have no issues in Linux Mint (though the Creative driver is not installed on Linux Mint) so I'm thinking it is more of a driver issue than hardware. I've rapidshare'd the Minidump file here.
[*]Did it work normally at one time, or has the problem always existed?
It's always seemed to be there, but much rarer than it is now. Used to happen once a month or so, now it seems everyday.
[*]I already tried these steps:
Checked temps under load-all fine.
Uninstalled Nvidia and Creative drivers, ran driver sweeper, and reinstalled them.
Doesn't seem to be tied to any certain application.
Ran Memtest86+ for 23 passes, no errors
Eliminated OC's
[*]My software:
  • Vista Ultimate 64-bit SP1 build 6001/I])
  • Antivir
  • Comodo
[*]My hardware
  • DFI Infinty II Ultra M-2 Nforce 4 socket AM2
  • AMD A64 X2 5000+ Black Edition @ 3 ghz
  • Galaxy 8800gt 512mb
  • 2x512mb and 2x1gb OCZ DDR2 800 with 2v going in
  • Seasonic S12 380w
  • Creative X-Fi XtremeMusic
[/list]
[/quote]
Gautama2
1,461
Says that it is most likely caused by ntkrnlmp.exe. That doesn't help too much. Here is the report. Is this a file I can just extract and replace from the install cd?
Microsoft (R) Windows Debugger Version 6.9.0003.113 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Aaron\Desktop\Mini072908-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\debug*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008 Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 6001.18063.amd64fre.vistasp1_gdr.080425-1930
Kernel base = 0xfffff800`01e1a000 PsLoadedModuleList = 0xfffff800`01fdfdb0
Debug session time: Mon Jul 28 20:32:46.160 2008 (GMT-4)
System Uptime: 0 days 2:50:59.528
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {fffff81801fab264, d, 0, fffff80001eeaca1}
Probably caused by : ntkrnlmp.exe ( nt!EtwGetKernelTraceTimestamp+31 )
Followup: MachineOwner
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffff81801fab264, memory referenced
Arg2: 000000000000000d, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80001eeaca1, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002043080
fffff81801fab264
CURRENT_IRQL: d
FAULTING_IP:
fffff800`01eeaca1 8b0c81 mov ecx,dword ptr [rcx+rax*4]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: System
TRAP_FRAME: fffff80002fee950 -- (.trap 0xfffff80002fee950)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000001 rbx=0000000000000028 rcx=fffff81801fab260
rdx=0000000020004000 rsi=000000000000000a rdi=fffffa6000dba2c4
rip=fffff80001eeaca1 rsp=fffff80002feeae0 rbp=fffff80001fab260
r8=fffff80001f93b80 r9=00000000000078e8 r10=0000000000000709
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz ac pe nc
nt!EtwGetKernelTraceTimestamp+0x31:
fffff800`01eeaca1 8b0c81 mov ecx,dword ptr [rcx+rax*4] ds:f050:fffff818`01fab264=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80001e6f12e to fffff80001e6f390
STACK_TEXT:
fffff800`02fee808 fffff800`01e6f12e : 00000000`0000000a fffff818`01fab264 00000000`0000000d 00000000`00000000 : nt!KeBugCheckEx
fffff800`02fee810 fffff800`01e6e00b : 00000000`00000000 fffffa80`0491f050 00000000`00000000 fffff800`02feeb30 : nt!KiBugCheckDispatch+0x6e
fffff800`02fee950 fffff800`01eeaca1 : fffffa80`0491f050 fffffa60`00da05ee fffffa80`0491ff00 fffffa60`00db321a : nt!KiPageFault+0x20b
fffff800`02feeae0 fffff800`01eead2f : fffff800`02feecb0 fffff800`02feebd0 fffffa80`0491ff00 fffffa60`00da0eee : nt!EtwGetKernelTraceTimestamp+0x31
fffff800`02feeb10 fffff800`01e70b1b : 00000000`00000000 00000000`ffffffff 00000000`00000000 fffff800`023405cb : nt!EtwGetInterruptTimeStamp+0x1f
fffff800`02feeb50 fffffa60`00d83062 : fffffa60`00d820d9 fffff800`00000001 fffff800`02feed50 fffff800`01f8e680 : nt!KiInterruptDispatchNoLock+0x13b
fffff800`02feece8 fffffa60`00d820d9 : fffff800`00000001 fffff800`02feed50 fffff800`01f8e680 fffff800`01e50979 : amdk8!C1Halt+0x2
fffff800`02feecf0 fffff800`01e8a7b8 : fffffa80`024a1bb0 fffff800`01f93b80 fffff800`02feedb0 fffff800`01e72a2d : amdk8!C1Idle+0x9
fffff800`02feed20 fffff800`01e79b31 : fffff800`01f8e680 00000000`00000709 00000000`00000000 00000000`00000000 : nt!PoIdle+0x148
fffff800`02feed80 fffff800`020475c0 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x21
fffff800`02feedb0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!zzz_AsmCodeRange_End+0x4
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!EtwGetKernelTraceTimestamp+31
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4812c3f7
FAILURE_BUCKET_ID: X64_0xA_nt!EtwGetKernelTraceTimestamp+31
Gautama2
1,461
Yeah I found that page, too. I don't really see what the resolution there is; microsoft tells him its his processor (microsoft tells me nothing); one says it is drivers (likely, need to find which one); another says it is his display driver not being able to address 4gb of RAM, which doesn't make much sense to me.
robisbell
Banned
Oct 27, 2007
3,621
memory should meet these specs at least for the motherboard.
Latency:4-4-4-12-2T
Voltage:2.1v
Format:240-pin DIMM
Module Types Supported:Unbuffered only
Error Detection Support:Non-ECC only
DDR2 SDRAM Frequencies:pC2-4200 and PC2-5300
unfortunately OCZ does not show specs for the ram, and DDR2-800 is listed as a unsupported speed, with a note that it's not guaranteed that the system will operate normally with unsupported speeds and that damage may occur.
robisbell
Banned
Oct 27, 2007
3,621
Latency:4-4-4-12-2T
Voltage:2.1v
Format:240-pin DIMM
