Need help determining cpu alarm setting
Horsepower
I have 2-P4 2gig and a P4 1.7gig. One 2 gig uses Intel Active Monitor and the other processors use MSI PC Alert III to monitor temps. The default cpu temp alarm limit is different on all 3. 2 are 845 boards, 1 is an 850. I use Fahrenheit, but can convert. What should the high alarm limit be? Thanks in advance for your input. These are stock not O/C'd.
I think the reason nobody is replying is because we are all jeleous. Anways 60C would be a good high to set it to. Though you can set it higher if you want. I would say max 70C though.
