need help deiciding on two cases
LongCoolMother
5,675
okay, i have narrowed it down to two selections:
coolerguys silver pro
or
Infamous Lian Li PC65
unless someone has a really good alternative for aluminum cases that are priced below $200, please dont recomened me any others thnx. So im thinking, the coolerguys case has the extra gamer ports and its like polished aluminum. the lian li charges extra for that stuff, and it also costs more by a fair margin. I just need to know whether the coolerguys case would provide just as well cooling and durability. Its a heck of a lot lighter too.. might i add that the lian li includes a free 300wt power supply. but i dont need it, because ill be using my existing one
jordo
if you dont need a ps, i would recommend buying the lian li here as it is $159 shipped (ups ground, i got mine in 4 days).
if you work inside your case a lot i would go with the lian li, as it is an amazing case inside, with a lot of touches that you really will notice. i personally think the brushed aluminium looks a lot better than the high polish, but then again i own a lian li so i am biased.
LongCoolMother
5,675
well, after shipping, i found that the coolerguys case is $129, and the lian li is $159. im lookinf at a $30 difference. im leaning twoards lian li because the price is not too much higher and it seems to be much more popular...keep on replying, thanks
