Need help deciding
xKaotiiKx
System Specifications:
I. Processor/CPU:
Intel 3820
II. Current Graphics Card:
GT 440
III. Display Resolution:
1920x1080
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications:
Corsair AX1200
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent):
NZXT Switch 810
Purchase Details:
I. Budget? Please be sure to include currency (If not USD), retailer preferences & specify whether rebates are a viable option.
$1000
II. Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)?
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI?
Yes
IV. Have you previously looked at a product(s) which you feel would fit your needs?
2 XFX HD 6970's (with water blocks)
2 Zotac 3GB GTX 580's (without water blocks)
3 EVGA 1.5GB GTX 480's (with water blocks)
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
I play GTA , BF3, Skyrim, CoD.
I want to be able to play games maxed out and get decent FPS
VI. Do you plan on overclocking the card you intend to purchase?
Yes
Nintendesert
7,761
7870's are better buys than 7950's... and Sol is right, Kepler is really really close, might as well wait a little bit longer.
nOOky
3,272
2,355
I second the above and I'd wait a bit also...
