Need help deciding which Mobo to get
Lob
Hey guys I've recently buying parts to upgrade my computer to the latest SB and narrowed down to 2 Mobo.
CPU: 2600k
Video: EVGA GTX 580 SC
Ram: CORSAIR Vengeance 8GB
SSd: Crucial M4 CT256M4SSD2
HDd: WD Cavier Black 2TB
Which one do you guys prefer ignoring the cost difference.
ASUS P8Z68-V PRO LGA 1155 Intel Z68:
http://www.newegg.com/Product/Produc...82E16813131730
vs
GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68:
http://www.newegg.com/Product/Produc...82E16813128506
Thanks in advance!
P.S: Probably should add that I'm basically looking at people's opinion on which is less prone to have problems. I know each user it's different but I've been out of the upgrading scene for a long time and would definitely appreciate some input here. Thanks!
is one better than the other?
They both have slight differences. Your best bet is to tick the compare boxes and then click the grey compare button at the bottom. In my opinion the asus is better but as I said I am an asus fan because of their looks and ease of use. Unless you can find a connector you need that is on one board but not the other or prefer the asus uefi BIOS then it is going to have to come down to price
P.s those links were supposed to take you to the relevant compare pages sorry they don't seem to work.
