- Aug 15, 2000
- 877
- 0
- 0
I'll be modifying my case in a couple of weeks. Need help deciding where to place case fans. So far, i have decided to put one 80mm fan in the front for intake, 1 80mm in the back for exhaust, 2 x 40mm hd cooler and maybe one 92mm on the top of the case.
Should i have any case fan on the side?
Is this a good setup??
I'll be using probably L1A panaflo or adda fans.
I was thinking of purchasing a fan baybus, but the fans i'm getting are pretty quiet already so not sure if i needed one.
thx for all that reply
