Need help deciding upgrade path for my current PC.
Neutralman
77
I just recently discovered these wonderful forums and have been educating myself on new forthcoming technologies. I am really excited about changes like BD, Ivy Bridge, 22nm GPUs, etc...
Here is my predicament! In a month, I am going on a foreign trip for 2 weeks and plan on doing lots of video recording in 1080p. I plan on moving these recordings onto my desktop, editting them, and burning them onto blu-ray media.
Based on that main usage, as well as some medium gaming, what do you guys think I should upgrade in my current desktop?
Monitor: Alienware AW2210 21.5 inch
Case: Full Tower NZXT Zero 1 Aluminum Body
Motherboard: ASUS X58 not sure of serials...
Operating: Windows Vista 64bit
CPU: i7-920 2.66ghz
GPU: Nvidia GTX 260
Power Supply: Corsair TX 750watt
Ram: 8gb 1333ghz Ripjaws
Hard Drive: 320gb 7200rpm
Cooler: Coolermaster V8
Do I need a new motherboard/cpu, windows 7, SSD, video card, or anything else? Should I upgrade something now, and wait for new technology on other parts? Any input is greatly appreciated!
BoomerD
66,728
15,127
You'd gain a bit by changing your boot O/S drive to an SSD, but unless you're going to drop big bucks into one of the faster 1366 CPU's, you're looking pretty good. If you do enough gaming to justify upgrading your video card, then there are some good deals to be had for that as well.
dma0991
2,723
A bigger HDD to store all that HD videos would be nice. A 1TB or 2TB HDD is pretty cheap now.
Davidh373
2,428
Vista X64 is windows 7 at this point. As long as you've got SP1, it will be identical in performance to Windows 7's initial release.
Now one thing I might recommend is a GPU upgrade in a year or so.
Nov 26, 2005
15,197
403
What program will you use to edit your 1080p vids? If Adobe PP Pro CS5, you will want to take advantage of the Mercury Playback Engine and get a GTX card. If you can afford a GTX 480, I recommend one.
mfenn
22,400
www.mfenn.com
About the only things that rig needs are some more storage (already addressed) and a GPU upgrade. I'd suggest the 6950 2GB as a good performing, reasonably-priced upgrade. I did the GTX 260 -> 6950 2GB upgrade myself and it provided a very nice performance boost.
