Hello guys. This will be my first home built computer. When it comes to computers, I know almost nothing. I have installed RAM modules, video cards, and PCI slot things of the sort, but nothing further, so I am pretty much clueless on how to set up a computer. Hopefully it isn't too overwelming for someone like me to jump into doing. I have great experience working on offroad vehicle engines, fine tuning/fixing up old cars, and have a great mechanical sense of how things work, so I think I might be able to get by with building a PC.
Okay, so enough about me, lets talk about my PC. I have decided to spend around 1,700-1,800 dollars on my new computer priced out from places such as newegg where I will being doing almost, if not all of my shopping. I have decided on an AMD 64 system being that I am going to be doing a fair amount of gaming, but I am more concerned on a system focused on rock solid stability with long lasting reliability over performance, allthough I am looking for the best balance between performance and reliability. How reliable and stable are the AMD64s if anyone has had some long term experiences?
I have chosen a 3200+ Newcastle 2.2ghz core and am pretty much set on that. I have everything from case, drives, and acessories in my wishlist for newegg, but there are two main things I do not know what to buy. The Motherboard, and the RAM. I hear so many things about compatability problems between the two and other things. I hear some good things about certain motherboards (MSI neo plat in particular) and then hear some totally awful things which absolutely ruin my desire to build my first computer being unknowledgable about troubleshooting these things. I had my heart set on getting this motherboard, but I am just hearing too many bad things about it. How is the Asus K8V Deluxe? I was thinking about getting that instead or maybe the MSI FIS2R. Any other suggestions? I am just looking for a board that would be easy to set up for a PC "newbie" as some might refer. It just seems like for every couple of good things I hear about a board, I hear a bunch of bad things, and so on and so on..
Next is the RAM. After someone helps me determine the best motherboard for stability, reliability, performance, and ease of setup I need a suggestion for RAM. I have heard that these A64s are really picky when it comes to RAM, that some is compatible, some that the cheapest ram works great, and some that you need 222 rated cas latency. How much of that should I take into consideration? I was thinking about going with the Corsair XMS PC3200 ram, but then maybe the OCZ PC3200EL which has lower latency and is around the same price, but then I heard some bad things about OCZ. So I am completely confused.
Anyone who can make a suggestion about anything based on my criteria will be very appriciated. Thanks a lot in advance for your input!
EDIT: I would also like to add that I do NOT really plan to overclock, and if I do, not by much. Maybe the 2.2 ghz going to about 2.4 ghz but nothing extreme, since I do not know anything about overclocking and I heard it reduces reliability..?
Thanks!
Thanks!
