Need help deciding on a Geforce 6800 brand to buy.
VigilanteCS
Hi,
I've got $324.13 (exactly) and I'm going to buy a geforce 6800 regular. I need help deciding on which brand to get. Mainly, I want the one that will run the coolest (I dont care about noise).
http://www.newegg.com/app/View...submit=property&DEPA=1
I can go up to the $285 eVGA. I'm thinking about going with the Leadtek, mainly cause it's only $270 and has 5 stars from voters, and runs pretty cool.
Which one do you all think I should go with?
eVGA, Leadtek, and BFG seem to be the most recommended brands. You'll have to dig up tests to find temperature differences, but I doubt that any differences you find will be significant enough to be worth mentioning. Just get the cheapest one of those three, and put an NV Silencer or other aftermarket unit on there if you need something more effective.
:thumbsup:
