Need help deciding on a chipset and motherboard for socket 1155
taweisse
I am getting ready to build a new computer to replace my laptop. I looked around and cant seem to find information about the chipsets for the 1155 socket motherboards. I am getting an i5 processor, not positive which one yet. Im looking for a cheap-ish motherboard, as i want to keep the whole build around 600 bucks, so under 100 for the board would be nice. Ill be using the computer for some light 3d gaming, and mostly for pretty heavy video editing in after effects, as well as some 3dsMAX. I want to get a decent discrete graphics card, probably a lower end one, and dont want to sli/crossfire. I'd also POSSIBLY want to get a good sound card in the future, as i record frequently.
It seems like all the motherboards ive seen have a ton of pci and pci-e headers (i think their pci - im a noob) that ill never use. If anyone could please direct me to a good chipset for my needs, or even better a cheap motherboard with that chipset, it would be very appreciated. Thanks.
IntelEnthusiast
Intel Representative
Feb 10, 2011
582
There are 5 main chipset sets for the socket 1155 right now. I will list them from bottom to top.
H61: this is our value chipset. The H61 boards will be the lowest cost boards but they will also be the boards with the lowest level of features. This board will support the processors IGP (Intergraded Graphics on Processor) and will not allow overclocking of the processor.
H67: This is a mainstream chipset. Good home and multi-media board. This board cost a little more than the H61 boards but they will have more features. This board will support the processors IGP and will not allow you to overclock the processors core speed.
Q67: This chipset is designed for business level boards and vPro systems. These boards will support VT-d and TPM. If you are looking for a home PC don’t go with this board the features on do nothing for you. This board will allow you to use the IGP and will not allow you to overclock the processors core speed.
P67: This board is designed with a performance user in the mind. These boards are feature reach for the enthusiast space. This chipset makes for a great gaming board. This board will allow you to overclock the core clock speed of the processor but will not allow you to use the IGP on the processor.
Z68: The Z68 boards are everything that the P67 is but with 2 other features. The first new feature on this board is the Intel® SRT (Smart Response Technology) or also called SSD caching. The second is support for the IGP (on most of these boards) including the ability to overclock it. Most of these boards are coming with the Lucidlogix Virtu software that will enable switching from the dedicated video to the IGP for best performance for the application that you doing. These are generally the most feature rich and expensive of the chipset.
For you most like you are going to be looking for a H67 chipset based board and I would be look at ASRock and MSI to get the best value.
Christian Wood
Intel Enthusiast Team
taweisse
thanks for the response, that really gave an idea of the features of each chipset, which i couldn't find before.
mmaestro
117
It may be worth thinking about if you're likely to have to do any quick transcoding, however. The only option you have to use both Intel's built in quick-sync transcoding hardware as well as discrete graphics is if you invest in a Z68 board. That'll put you over $100 - possibly well over $100 - however if you're likely to need very fast, good (not great: great transcoding right now will use the processor) transcoding then Z68 is well worth considering.
taweisse
OK, so i'e been looking around and it looks like i'm going with the z68 chipset. There are so many benefits to that one which aren't in any others. I found one from gigabyte for 124 bucks (and probably cheaper else ware), with everything i want.
http://www.newegg.com/Product/Produc...82E16813128495
If anyone who knows more about this stuff could just take a look and tell me if its worth buying. Also, none of the boards say they have a video chipset, but I wanted to use the processor's built in graphics, without a discrete card. This board has an hdmi plug on it, does that mean i will be able to do this?
thanks
sm625
8,172
137
Only intel could make a chipset that doesnt even give you access to 20% of the cpu. It sounds like you arent overclocking so it looks like H61 is for you.
BonzaiDuck
16,745
2,104
thanks
I say "Go for it!" since I believe you should get what you want. Even if you're not an over-clocker or enthusiast, if you're building your own and have the patience for this sort of thing, the extra features of Z68 are significant if not substantial. Just be sure and ask yourself "I'm buying this board to use as much of it as I can."
Also, thanks for pointing up the availability of that Gigabyte mATX board. If prices drop a bit on that model, I may pick up a couple to upgrade some machines in the fam-damn-ily.
As it stands, they may replace two $80 Gigabyte mATX boards which -- for their price and vanilla features -- have been standup reliable. While I've gone with ASUS for my own Z68 machine, I don't think your going to miss anything for what you intend to do with the Gigabyte.
And -- yes- you can use the processor's iGPU without a more expensive vid card. That's what the motherboard's plugs, including the HDMI, are for . . .
taweisse
thanks bonzai. Im pretty sure im going with the z68 board, but i was just looking around at some h67 ones as well. It dosent allow for overclocking, but i wasnt planning on doing so anyway. It can use the processors igp (plus), but lacks intels SSD caching, as well as the Virtu software capabilities. (I am planning on eventually getting a discrete graphics card.)
Are the extra features on the z68 boards really THAT significant? I am trying to get the best possible machine for the least cash, and h67 boards are quite a bit cheaper, so im kind of interested in them.
thanks for any help you can supply
john3850
1,436
21
Never knew a mb could be made so poor untill I bought a Asrock z68-pro3.
Every piece of plastic is about 30% thinner,shorter,narrower.
If you switch out parts a few times stuff will break.
I pressed in the memory very slowly cause Dimms are lower and thinner.
The sata slot on a ssd are thicker then the sata ports on the mb.
I used lube on the 24 pin power connector so it wont break when I remove it.
Every piece on the IO pannel bends when your just pushing in a usb or ps2.
Dont even think of using Viedo out ports cause if you move case with the monitor cable in your connector will pull off the mb.
The tiny pci-e slots will barely hold a double card with or without a screw.
The mb does work good which is the only good thing I can say.
If your a big brute of a person stay away from this cheap board.
BonzaiDuck
16,745
2,104
I'll have to look up that model.
The OP had asked "Are the extra features on the z68 boards really THAT significant?" And I have made my own conclusion: "YeS!!"
SSD drives, for sure, are expensive, coming at a high premium per GB. If you buy a 20GB or 60 GB SSD, however, for maybe $100, you can increase the performance of a $55 1 TB SATA II drive by as much as 400%. On the Lucid Virtu -- and with or without it -- I'm looking forward to a dual monitor system and having two heterogeous graphics cards working together. While at the moment, graphics performance judgments about this part of it aren't too stellar, others have touted it because it works. There should be a way to tap that extra graphics power to great benefit.
Especially I'm happy with the ISRT feature, because I have been running a four-drive array in RAID5 off a $350 controller for about four years. The "read" performance improvement has not been that much, and the "write" performance falls at least 60 MB/s behind what ISRT gives. Since the power consumption of an SSD is less than a watt, I can expect progress with this in trimming my electric bill while increaseing "read" and "write performance way above what I had spent -- lessee . . . um . . . $350 + (4 x $70) + (2 x $70) = $770. Let us pause for a minute while I hang my head in shame . . . . The extra pair of drives had been purchased to have on hand if one of the drives in the RAID5 had failed. Turns out -- I didn't even open the anti-static seal on those drives until two months ago -- and one of them had been "DOA" from the time I bought it . . .
Whatever anyone says about the Sandy Bridge, they over-clock really well and you can reap the benefits of it with one of the "K" chip versions, since your board will automatically enable "Turbo-Boost" and boost the speed above the stock value by about 400 Mhz -- without any effort at all on your part. Good RAM is cheap. But especially, we must have waited a long time to open up this hard-drive bottleneck at the "bottom of the pyramid." It is always the largest storage device that is likely the slowest, which always costs the least (per GB). Now -- the bottleneck is open . . .
EDIT: Well, John . . . . It's a budget mATX board. I'm only glad now that I no longer buy high-end boards. I'm actually wondering if the mATX Z68's only cost as much as this because it's such a recently released chipset. I also think the prices might be edging up, but there's also evidence to the contrary.
I still keep my iron in the budget fire -- for the fam-damn-ily. I got two $80 mATX-ers in '08 to upgrade two systems, and they're still rock-solid and going strong. But you're not going to get "Ultra-Durable-3" or "16-phase power."
With the uncertainties in the news looming, I myself might have got that board -- and think of it -- I would have been able to get a beefier Z68 model later and simply transfer my hard-disk with no need to reinstall windows and only some chipset and other drivers to update or change . . . .
[Will Newegg cancel my "no interest until July 1, 2012" after the government defaults?]
taweisse
Wow thanks for that info Bonzai, Ill be going with a Z68 after all. Ill get a small, matbe 30 gig ssd for my os and for the SRT cache, and like you said get probably a TB for my storage drive. The board that valir posted seems awfully cheap, is it any good? It seems alright, but im not sure.
micrometers
3,473
My impression has always been that higher end boards are good if you are an overclocker.
If not (I'm not) then just get the cheapest you can find?
KingRaptor
52
Be careful when going for boards that are too cheap from 2nd tier manufacturers. Although feature and chipset wise they may be comparable to more expensive boards, build quality and defect rate could be much higher.
Asus and Gigabyte are safe choices. Personally, I've always used Asus boards as I have a few friends' Gigabyte boards degrade and stop working after 3 years.
