I've built a couple systems but my knowledge is based on building what others have suggested and the feedback they've gotten...so I know very little but here's what I have in mind.
I can buy one of two premade systems:
Gateway FX4710-UB003A Core 2 Quad Q9300(2.50GHz) 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista Home Premium 64-bit - Retail (about 1050.00 from newegg)Link to Newegg
Or for the same price
iBUYPOWER GS-925 Core 2 Duo E8500(3.16GHz) 4GB DDR2 500GB NVIDIA GeForce 9600 GT Windows Vista Home Premium 64-bit - Link to Newegg
Or for about $125 more I can build this (and use my old windows XP home instead of Vista 64
GIGABYTE GA-X48-DS4 ATX Intel Motherboard
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model HH80562PH0568M - OEM
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
SAPPHIRE 100243L Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
CORSAIR CMPSU-750TX 750W Power Supply
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA Model SH-S203N
NZXT TEMPEST Crafted Series CS-NT-TEM-B Black Steel / Plastic ATX Mid Tower Computer Case - Retail
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - (Plus mounting bracket)
This is someone else's build (which seemed good and stretches my $ to it's upper limit)Here's the link to the builder's post in another forum
So here's my concerns... (BTW I am doing mostly Photoshop, video editing and some gaming....)
Will this system be as effective running XP as Vista?
Should I use DDR3 memory
Is it really worth it (I am NOT going to OC anything...) or should I just buy the premade one and call it a day (I haven't purchased a system like that since 1995!!! Aleays been skeptical of them...)
I really appreciate your input- I'm working off my laptop and it bites
