Need help de-bugging a Javascript menu - Problem solved, nevermind
Beau
Site: PYRAmatrix Structures, Inc.
Menu JS file: link
Menu generally works fine except when you hover on a parent cell, drop down into the subnav bar, then move back up to a different parent cell. The subnav doesn't dissapear like it should, and the new subnav displays overtop of the old. whats going on?
Nevermind. I ended up creating a new function that goes through all page elements and determines if they are a menu by analyzing the id of the tag. If so, it hides it no matter what. Thanks anyways guys.
