liddabit
I am planning to build a new computer, and this is what I am planning for it so far. I am not sure how well all this will work together. Mostly worried if the new PSU is enough wattage. Also on the memory, it is at such a low price, is it worth buying 2 of the 8gb sets for 16gb? Sound is important , as well as cool temps. I live in Arizona and sometimes in the summer it can get hot in here.. well not really hot but 80F degrees around the PC. Thanks in advance!
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
SeaSonic X Series X650 Gold ((SS-650KM Active PFC F3)) 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
MSI R6950 Twin Frozr II OC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
GIGABYTE GA-Z68X-UD4-B3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Microsoft Windows 7 Professional SP1 64-bit
Corsair Carbide Series 500R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
I already have a sound card and hard drive from my existing computer.
Oh , I guess I should mention what it is for. Basic gaming. Mostly Rift right now. With work I don't get much time off to do other games. Eventually I want to try Deus Ex 3. I do a new build about every 3 years. minor upgrades every 1 year. I don't plan on overclocking. Budget isn't much of a factor, but I would like to keep it in the range of the parts I have selected here.
Ohh! Also.. I haven't built a new pc in a long time. Last one was 5 years ago. Amd X2 was my last processor. How important is thermal paste now? Should I invest in something like arctic silver like I did in the past? or will the Thermal tape that seems to come on stock coolers work well enough if I don't overclock? Thanks 🙂
