need help creating a class in C++
piski
312
I have created the file rect.h it contains the following code:
class Rectangle
public:
Rectangle();
void relativeSize(double factor);
void changeLength(double num);
void changeWidth(double num);
void showSides(string color);
double area();
double perimeter();
double getLength();
double getWidth();
private:
double length;
double width;
I am getting an error on the function void showSides(string color). It is saying that 'string' is an undeclared identifier..why?
second. I have created an implementation file as well called rect.cpp. My header statements are this:
#include <iostream>
#include "rect.h"
using namespace std;
is this the proper way to do that? It is telling me that there is a missing ; before 'using'..
thanks
k
piski
312
okay i included the string header in my implementation file and is giving me an error:
rect.h(14) : error C2061: syntax error : identifier 'string'
what is this now?
thanks
K
Barnaby W. Füi
12,343
Originally posted by: screw3d
Originally posted by: PrincessGuard
Actually it's #include <string>
I think it depends on the compiler?
:eek:
So do you always just leave the .h out?
For standard c++ headers, yeah, there is no .h, but compilers still supply iostream.h and whatnot, for backwards compatability with pre-standard C++. But the standard is six years old. :)
dighn
22,820
4
also for c library headers like <string.h> <stdio.h>, you remove the .h and add a c in front of it eg <cstdlib> <cstdio> <cstring> etc
