Need Help cooling a Geforce 2 MX
Drifter
>Have the Asus Geforce 2 MX which has a heatsink on it.Is there a Fan I can buy that will mount right on to the heatsink? Or am I better off removing it and getting the BlueOrb Video Chipset Cooler.
>Anyone who installed the fan on there Geforce 2 MX. Where you able to overclock the Memory to 210 Mhz?
>Thanks in advance.
I put a fan on mine, the Fan doesn't help the memory any, but it helped my core alot, I can OC the core to 250 (max on the slider), but I get artifacts, I can get up to 242 with no artifacts. I dunno where you can get a fan at, I just took it from my old TNT 1
Drifter: I have a CardExpert GeForce 2 MX that also came with a heatsink but no fan. I bought a new fan for a 486 CPU and attached it to the heatsink. It fits perfectly and works great.
I'll give the 486 Fan a try. Hoping with the fan the memory would do 210 Mhz. From Actaeon...It doesn't sound to good 🙁 Thanks for the replies.
I have no problems running my V7100 at 200/200 without a fan. General air flow through the case seems sufficient.
