need help connectng reset/HD/speaker LEDs on my DFI mobo
astnfan
Hi there,
I have the DFI lan party UT nF4 ultra D mobo and I a going through the manual and it specifies what the configuration of the front panel connectors on this page:
http://www.dfi.com.tw/Upload/Manual/lputnf4%20847505101.pdf
(pages 63-64)
My case has these connectors, but the manual does not specify what colors go where.
On my case the wires are as follows
HD LED: 2 pin orange and white wires
reset sw: 2 pin both wires are grey
power sw: 2 pin blue and white wires
there is another 2 pin connector with green and white wires only labeles + and -, the + is green and the - is white : i have no idea what that is for
I am clueless on how to place these cables, is white the ground?
Can anyone help, I would be most greatful.
Usually the colored wire indicates the + side, but as these wires will not damage anything that is plugged in wrong, plug them in and see if it works, if not just turn the wire around
