MikeyLSU
I have an E4300 OC to 2.4 and a DS3 rev 3.3
Pic of Temps
OK, so I have core temp .94 and .95 and obviously they are reading 15 degrees apart. TAT is also reading closer to .95 But what I don't understand is why the temps are this high on idle.
I am using stock cooling, but which reading is correct? I just restarted to check the temps in the BIOS, and the CPU temp was 35 if that means anything.
Until today, all I was using was coretemp .94 and was about to push further, but seeing these higher temps, I am tempted to pull back some. Which one is correct? Also notice that .95 lists it as a Conroe-2M for some reason.
BTW: I know that Coretemp .95 is not 100% accurate because when I stress it using ORTHOS, it reads the temp as 72 degrees. I have my BIOS set to warn me/shut down at 70.
Pic of Temps
