- Dec 20, 2009
- 7
- 0
- 0
Hi!
My old computer died (the MB) a month ago and i just got this week the new parts i ordered. I bought a P7P55D motherboard with a Core i5 and 4GB of Corsair DDR3 Dominator memory (8-8-8-24 got a deal on these). I also replaced my old 8800GTX with a brand new and completely shiny XFX Radeon 5850 to get the HDMI audio out since i'm using my PC as a media center
Love this card so far.
After flashing the bios to the last version, re-installing Windows 7 and the MB drivers i quickly opened CPU-Z to see if the MB recognized my hardware corectly (it almost always never perfect) and found that some numbers was weird.
I must admit i'm a little lost with things like XMP, QPI and such.
For one the bus speed reported by CPU-Z is 133MHz. Weird from what i recall my old Opteron 180 bus speed was 200MHz ... could be wrong is it normal ? Also the core speed reported is 1203.7MHz. Is it the core speed of the cpu ? If yes why it's not at 2.67GHz like Windows tell me in the system properties ?
I have DDR3 at 668.8MHz frequency. Since the bus speed is at 133Mhz and this is DDR3 why it's not working at 3x133MHz ? From what i recall my old system had DDR2 400 memory working at twice the speed of the bus (2x200MHz = 400MHz).
I'm really completely lost with this new DDR3 memory.
My ram is set at 9-9-9-24 while it is supposed to be 8-8-8-24. From what i understand i need to enable XMP setting in my bios but by doing so my ram will have a frequency of 800Mhz so how is it possible with a bus speed of only 133MHz ?
Also in my MB manual it is said when enabling XMP to use only one ram module by channel so am i going to lose dual channel ? If yes is XMP worth it over dual channel ? Do i need to set anything else in the bios while enabling XMP since the ram will work at a higher frequency than the system from what i understand (or not understand) ?
Last n00b question there's 2 settings in the bios i'm not sure if i need to disable. Intel Speedstep Tech and Intel TurboMode tech­. From the small description in the bios it's not really things i would want to use but dunno a better explantion than 3 words would probably help me to understand what both are exactly doing.
Thz in advance to all knowledgable people who will spend time answering these n00b questions.
