need help, combining system bios with rocket 133s controller
kingmike
Just got a rocket 133s ata 133 controller and need to combine its bios with the systems so I can boot from it.
What I need to know is, what is the combine program that actually combines both bios files.:confused ;
Umm... you shouldn't have to combine BIOSs or anything like that (which is not really possible anyway). What you need to do is get your new controller card plugged in, then in the system BIOS change the boot drive to the controller card. Every motherboard does it different, but you should see choices to boot off any of the 4 channels on the controller card.
Make sense?
Rocket133S
HighPoint Technologies Rocket133S Host Adapter
The Rocket133S Host Adapter is a single channel IDE controller card designed for use with ATA133 hard disk drives. This Host Adapter is an ideal upgrade for those looking to add basic ATA133 support to their PC's. The Rocket133SB is a better choice for those looking to add bootable ATA133 support to their systems.
Single ATA channel operation for high-performance data storage and retrieval
The Rocket133S supports high speed transfer rates up to 133MB/s. It's ATA single channel support up to 2 hard disk drives.
Supports high-capacity hard disks
The Rocket 133S Host Adapter breaks the current interface standard's hard disk drive capacity limitations, and supports hard drives larger than 137GB.
Multiple OS support
The Rocket133S Host Adapter is compatible with most major operating systems, including DOS 5.x, Windows 3.1x, Windows 95/98, Windows ME (Millennium Edition), Windows NT 3,51/4.0, Windows 2000, Windows XP, and Linux (SuSE, Red Hat, Caldera, Turbo).
Rocket133S Specifications
Host side interface
32bit 33/66 MHz PCI
Device side interface
Ultra DMA/ATA133
RAID controller IC
HighPoint HPT371 UDMA ATA133 Controller
PCB
4-layer, Low profile
Number of IDE channels
1 Channel
Supported Hard drives
ATA133 hard drives, backward compatible (ATA100, 66, 33)
Supported OSs
Windows 98/ME, Windows NT4.0, Win2000, Windows XP,Linux (Turbo, Caldera, RedHat, SuSE)
Maximum Data Throughput
133MB/s per channel
BIOS Function
Drive Configuration and Management
Plug and Play
Yes
Misc. Functions
Bootable disk support (if Combine-BIOS is implemented)
Large LBA support capacity exceeding 137GB
It sounds like you can't boot off something plugged into this card... the "S" vs "SB." If it's not telling the system BIOS that it's got bootable hard drives attached, you may be SOL... I've never personally run into a card that didn't allow booting off of it, though. Doh
