Redchicago
A friend just installed a new motherboard in my computer (Asus P5N32-E Sli 680i) after I had been experiencing a ton of problems with my GA-P35-DSR3. Since the installation 2 days ago, I've had very high CPU temperatures. High 40s-50s at idle and 70-80 when gaming (WoW).
Perhaps I didn't seat my stock heatsink (e6600) correctly, so I plan to redo it tonight after I buy some more thermal grease.
Since I have to stop off at MicroCenter to get some thermal grease, I thought perhaps I would invest in a heatsink better than the stock intel one that comes with my CPU.
For the moment, I am stuck with the poor offering at MicroCenter (want to get back up and running asap and don't want to wait a week to get one from Newegg).
MicroCenter
I don't want to have to redo the the entire installation of my motherboard, so could someone recommend a decent cooling system under $75 that will fit on my motherboard and not require me to take out the board to do the installation (ie. back brackets like in the Zalman models).
Thanks!
MicroCenter
Thanks!
