Hi Guys,
I need help choosing the best GPU for my system to avoid bottlenecking.
My present build -
AMD Phenom II X6 1100T
Asus M4A88T-M LE
Transcend 4x2gb DDR3
Radeon HD6750
Zebronics 700w PSU (Yes I know :\, will change it in a couple of months)
http://www.zebronics.com/products/platinum-series/zeb-700w
I have narrowed it down to these two, the R7 265 and R9 270 (not the X).
What would you guys suggest? Are these GPUs suitable for the rest of my config or should I get anything more/less powerful.
Thanks
My present build -
Asus M4A88T-M LE
Radeon HD6750
Thanks
