IMHO:
Get either one of the following.
The patriots from fry's are specified at a bit lower latency,
but a 2.0V power setting to achieve it, and you have to jump
through the rebate hoop.
The SuperTalents from eWiz cost a couple of dollars more
(probably near identical after shipping differences), but
there's no rebates to delay you either.
Either set is rated for 400MHZ stock speed, and with a P5K-E
(I have one and a Q6600 running) you'll have a x9 max. multiplier
for the CPU and 400x9=3600MHz CPU speed @ stock RAM speed.
If you OC the RAM to 440MHz, 440x9=3960MHz which is almost
CERTAINLY FASTER than you'll be able to successfully overclock a
Q6600-G0 (or any previous stepping!) even if you use a good $400ish
water-cooling setup for the CPU and over-volt it fairly much.
It's not UNCOMMON for people to get limited overclocks around
3.6GHz up to maybe 3.8GHz if they're very lucky on the best
available air cooling heatsinks.
The "ThermalRight Ultra 120 Extreme" $65ish heatsink is about the best
one you can get for air-cooling the Q6600, and with that and a couple
$4 D12SL fans (jab-tech has them cheap) you're all set to overclock
a Q6600 up to around 3.6 or maybe (don't count on it) 3.8 GHz.
So basically either of the the 400 MHz RAM (PC2-6400 DDR2-800) sets
is fine since you'll very likely be able to get up to 425MHz out of it
which is about all your CPU cooling and CPU could probably realistically
handle in any optimistic scenario. Spending more for faster RAM is not
really worth it since the CPU couldn't go much faster anyway even
if the RAM was faster, and the added advantage of the RAM speed
being a little faster is basically irrelevant for a Q6600 CPU, it's
best to just run the CPU:RAM at 1:1 around 440x8.
Or you could generally aim for somewhere around
3.3 to 3.8 GHz CPU speed at either CPU x9 or CPU x8
with the ram running between 420MHz and 450Mhz however fast
it can go at the same clock as the CPU or somewhat higher depending
on your available RAM multipliers at the speed your CPU limits at.
I'm running two P5K / Q6600 systems so I am pretty confident about all
the details of what'll work for your setup.
I bought the G.SKILL 5-5-5-15 PC2-6400 ram for my 2nd Q6600, but
at the current price the stuff below is a much better deal for the same
performance.
$103/2x2GB=4GB, no rebates to hassle with.
http://www.ewiz.com/detail.php?name=T8UB2GC5&show=p
SuperTalent manufacturer
Specification
o Mfr Part Number: T8UB2GC5
o Type: DDR2
o Capacity: 2 GB
o Speed: PC6400 800MHz
o Size & Bit: 128 x 8
o Pins: 240pin
o ECC: No
o Registered: No
o Super RIGID
http://shop1.outpost.com/produ...sr:SEARCH:MAIN_RSLT_PG
$99/2x2GB=4GB after you get back the $50 rebate.
DDR2 4GB PC6400 DUAL PATRIOT
$50.00 Rebate
PATRIOT:
FRYS.com #: 5200607
PDC24G6400ELK
* Extreme Performance
* DDR2 4G (2x2GB)
* PC2-6400 (800MHz)
* Enhanced Latency DIMM Kit
The Patriot Extreme Performance PC2-6400 Enhanced Latency line is engineered to provide PC enthusiasts and gamers enhanced memory performance without breaking the bank. Capable of operating at 800MHz with a latency of 5-5-5-12, it is equipped with Patriots own bladed heat shields to ensure system stability while running under extreme overclocking conditions. Available in 512MB to 4GB kits, these memory modules are compatible of performing with the latest AMD and Intel DDR2 platforms allowing users to speed up their system instantly.
http://www.patriotmem.com/prod...oupid=38&id=593&type=1
Features
* Extreme Bandwidth PC2-6400 (800MHz)
* Enhanced Latency (5-5-5-12)
* Bladed aluminum heat shields to improve module stability
* 100% Tested and Verified
* Lifetime Warranty
* RoHS Compliant
* EPP Ready
