Question Need help choosing HDDs for RAID 5
ananmakoto
4
I was looking for some advice on what would be most cost effective. My plan was to use 3 drives in a RAID 5 array. This would be for home use to store my media files. I was looking at HDDs in the 6-8 TB range in size. I'm a little bit lost on how concerned I should be with the RPM of the drives and if I should even bother with the drives that have enterprise features.
Thanks for the help.
Shmee
Memory and Storage, Graphics Cards
4,614
619
IIRC, you want WD golds. Its been a while since I did anything with RAID though. EDIT: is this for a NAS? type server? What RAID controller are you using, or is it software? For a home NAS, reds red pros should be fine.
Shmee
4,614
619
Is this your only desktop? If so you should have a backup solution, which RAID is not. Also, what are the specs of this desktop and what RAID card would you use, if any?
I would recommend going another direction and getting a dedicated NAS. It could even be built out of an old computer, using freenas or the like.
ananmakoto
4
Yes, it's my only desktop.
Here are the specs:
Intel Core i7-9700K
Gigabyte Z390 AORUS PRO WiFi
Patriot Viper Gaming RGB Series DDR4 3600MHz
ADATA XPG SX8200 Pro 1TB - System Drive
no RAID card
NAS would be something further down the line when I have more money. In the meantime, I need to replace the two older drives I was using for media storage. Should I just not even bother with RAID?
Shmee
4,614
619
I wouldn't bother with the built in motherboard RAID. Can just be headaches, I would just have storage drives individually with backups.
Reactions: corkyg
ASK THE COMMUNITY
