Hello I am trying to buy a GPU for my computer. I came down to three options:
Gtx 660
http://www.amazon.com/EVGA-GeForce-S...ywords=gtx+660
Radeon HD 7850
http://www.newegg.ca/Product/Product...82E16814131472
Radeon HD 7870
http://www.newegg.com/Product/Produc...82E16814150604
Which of these options seem best to you? Do you think there are other candidates than the ones I posted? (My budget is 200-350)
Also are the ones I have chosen compatible with my current system?
I do not plan on over clocking myself. I plan on playing relatively high end games such as the Witcher 2 and Planetside 2 on high graphic.
System Information
Operating System: Windows 7 Ultimate K 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-890GPA-UD3H
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Phenom(tm) II X4 965 Processor (4 CPUs), ~3.4GHz
GPU: AMD Radeon HD 6870
Memory: 8192MB RAM
Available OS Memory: 8188MB RAM
Page File: 4088MB used, 12286MB available
Windows Dir: CWindows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disable
DxDiag Version: 6.01.7601.17514 32bit Unicode
Resolution: 1920 x 1080
Power Supply: Power Supply Seasonic S12II 520W E{S 12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PIC-E W/ 120MM Fan (2 years old)
Case: Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio
Gtx 660
Radeon HD 7850
Radeon HD 7870
System Information
Memory: 8192MB RAM
