I am planning on getting 16 GB (2x 8 GB) of ECC RAM on this motherboard:
http://www.supermicro.com/xeon_3400/Motherboard/X8SIL.cfm
I'm not going to be overclocking my RAM, and my main criterion is maximum stability. Some of the reviews I've been reading say that this motherboard is a bit picky about the RAM that it works with. The site above has a tested memory list, but it doesn't have a lot of tested options for 8 GM RAM modules.
It looks like my RAM options are these (I've linked the .ca page since I'm buying in Canada):
http://www.newegg.ca/Product/Product...eId=1&name=8GB
There's a couple more options here for matched modules though that doesn't matter since I the motherboard doesn't support dual channel RAM:
http://www.newegg.ca/Product/Product...2%20x%208GB%29
I have a few questions. Any comments on the relative quality of Kingston, Wintec and Patriot RAM? One of the modules is "parity" RAM, will this still work on the motherboard I've pointed out? Most of the modules I've pointed out are CAS latency 9, but there's one at 7, should I consider that one as well? And in the end, which RAM(s) should I be looking to buy?
Thanks for any help!
