Ive narrowed it down between 2 cases but having a hard time deciding.
I will be using this case for an Athlon 64 939, I most likely willnot OC or very little. I will be using an OCZ 470w PS not one that comes with case.
First case.
http://www.crazypc.com/Merchan...Product_Code=PX8131DBM
Black Fire Dragon Case Mod (PC-61)
* All aluminum construction with superb Lian-Li quality
* Black Fire Dragon window panel
* Cold Cathode Light Kit (OPTIONAL - your choice of color is listed above)
* Anodized aluminum finish
* Removable motherboard tray
* Fan filters for front fan
* Motherboard connectors for power, reset, led headers.
* Easy access side panels with thumbscrews
* PCI Slot covers with thumbscrews
* USB ports on front of case
Total cost with mods - $200
Pros
1. cool dragon side window
2. Lian quality
3. easy to upgrade
Cons
1. Cost
Case 2
http://www.xgbox.com/
Viper case
Bays: 4x5.25?, 2x3.5?, 4x3.5? Hidden
- I/O Ports: 2xUSB 2.0, Firewire, Spk & Mic
- Blue UV Acylic Window
- Painted Chassis
- Red LED Lighted Viper Emblem
- Includes Two LED Fans
- 500W P4/AMD - SATA Ready, Dual Fan, Power Supply
- Top DUAL Handles
- High Gloss Paint
- Static Guard (Rear Cable Management)
- Material: 0.7mm SECC
- Dimensions (WxHxD): 220 x 485 x 535mm
- 4 Colors: Black/Red, Red/Black, Black/Blue, Blue/Black
Total Cost = $100
Pros
1. 1 - 120mm fan upfront, 2 rear 80mm fans.
2. I like the looks with the Viper side panel and gloss paint.
3. Cost
Cons
1. Do not know alot about xgbox, cannot find any reviews on this case.
I am leaning towards the Viper case as its $100 cheaper and the cost of my pc keeps going up 🙂
Any commends, thoughts, recommendations.
Thx all 🙂
First case.
Pros
2. Lian quality
3. easy to upgrade
Cons
1. Cost
Case 2
Viper case
- Painted Chassis
- Top DUAL Handles
- High Gloss Paint
Total Cost = $100
Pros
3. Cost
Cons
Thx all 🙂
