Lyricsrid3
couple things to note:
+ CANADIAN prices, vendor ncix.com
+ purpose of computer: content creation (vg map dev, imaging, flash, html, web programming etc) AND game rig
+ I want to overclock
+ i am only buying a comp tower, absolutly nothing else (i have rest alrady eg monitor, headphones, etc...)
Desired price range: 2000$ canadian
$171.00
http://search.ncix.com/productdetail2.php?noheader=1&sku=13747
Case: XG TITANIUM 17IN ATX STEEL TOWER CASE 5X5.25 2X3.5 3X3.5 INT SILVER NO PS W/ WINDOW
1 ---------------------------------------
which Processor:
http://search.ncix.com/productdetail2.php?noheader=1&sku=15708
AMD Athlon 64 X2 3800+ Dual Core Processor S939 Manchester 2Ghz 512KBX2 90NM Retail Box
$385.02
http://www.ncix.com/products/index.php?...14633&vpn=ADA4200BVBOX&manufacture=AMD
AMD Athlon 64 X2 4200+ Dual Core Processor S939 Manchester 2.2GHZ 512KBX2 90NM Retail Box
$460.73
^comment^ these CPUs already come with ood heatsinks? or buy additional?...
2 ---------------------------------------
Which mobo?
http://www.ncix.com/products/index.php?sku=16595&vpn=A8N32-SLI-DEL...&ma
ASUS A8N32-SLI Deluxe ATX S939 NFORCE4 SLI X16 DDR 2PCI-E16 SATA2 RAID Sound 2GBLAN 1394 Motherboard
$256.50
^comment^ This allows for x16 SLI instead of x8... this is apparently not a major difference right now, but later on it will?
http://www.ncix.com/products/index.php?sku=13423&vpn=A8N-SLIDELUXE...p;manuf
ASUS A8N-SLI Deluxe Motherboard NFORCE4-SLI S939 DDR 2XPCI-E16 2PCI-E 3PCI SATA RAID LAN Sound 1394
$240.54
^comment^ This allows for x16 SLI instead of x8... this is apparently not a major difference right now, but later on it will? reviews don't like built-in sound on this mobo...
http://www.ncix.com/products/index.php?sku=15495&vpn=A8N-SLI%20PRE...M&m
ASUS A8N-SLI Premium ATX S939 NFORCE4 SLI DDR 2PCI-E16 2PCI-E 3PCI SATA RAID Sound GBLAN Motherboard
$215.86
^comment^ if the "premium" is a higher-end version than the deluxe as said, why is it cheaper at vendors? From what i can tell/have read it has the same features as deluxe but cooling using no-fan technology to make it quite, this makes it cheaper?!!?
Memory:
http://search.ncix.com/productdetail2.php?noheader=1&sku=14504
OCZ EL Platinum PC3200 2GB 2X1GB DDR400 CL2-3-2-5 184PIN Pin Dual Channel Memory Kit /W Ramsink
$324.23
IDE Hard Drive:
http://search.ncix.com/productdetail2.php?noheader=1&sku=11069
Western Digital Raptor 74GB SATA 10000RPM 8MB 4.5MS Hard Drive 5 Year MFR Warranty
$210.90
^comment^ i have several other hard drives to store files, this is just for OS and installs... (good right?)
3 ---------------------------------------
which video card?
http://www.ncix.com/products/index.php?sku=16260&vpn=256-P2-N525-A...mp;manu
EVGA E-GEFORCE 7800GTX 256MB 256BIT DDR3 PCI-E Dual DVI-I HDTV VIVO SLI Ready Video Card Retail
$589.39
http://www.ncix.com/products/index.php?sku=16693&vpn=256-P2-N527-A...mp;manu
EVGA E-GEFORCE 7800GTX 256MB 256BIT GDDR3 PCI-E Dual DVI-I HDTV VIVO SLI Ready Video Card W/ ACS3
$578.56
^comment^ how does ADDING ACS3 cooling make this card cheaper?
http://www.ncix.com/products/index.php?sku=17529&vpn=3056&manufacture=Connect3D
CONNECT3D Radeon X1900XT 625MHZ 512MB 256BIT 1.45GHZ DDR3 PCI-E16 Dual DVI-I VIVO OEM Video Card
$628.24
http://www.ncix.com/products/index.php?sku=15841&vpn=256-P2-N518-A...mp;manu
EVGA E-GEFORCE 7800GT PCI-E 256MB 256BIT GDDR3 Dual DVI-I HDTV VIVO SLI Ready Video Card
$459.89
4 ---------------------------------------
which Power Supply?
http://search.ncix.com/productdetail2.php?noheader=1&sku=13610
OCZ OCZ45012U-450W Modstream Power Supply PCI-E Ready W/ Ezmod Cable System & Blue LED Fan
$92.26
http://www.ncix.com/products/index.php?sku=13609&vpn=OCZ52012U&...nufactu
OCZ OCZ52012U-520W Modstream Power Supply PCI-E Ready W/ Ezmod Cable System & Blue LED Fan
$115.24
^comment^ SLI ready... as well
http://search.ncix.com/displayproductde...5&vpn=ELT620AWT%20&manufacture=ENERMAX
Enermax Liberty ELT620AWT 620W ATX12V V2.2 20/24PIN Modular Cable Power Supply W/ 120MM Fan
$192.66
^comment^ SLI ready... but worth it?
5 ----------------------------------------------------
which DVD Writer?
http://search.ncix.com/productdetail2.php?noheader=1&sku=10510
Sony DW-U14A DVD-R/RW 4X2.4X8 DVD+R/RW 4X4X8 CDRW 24X10X32 IDE Burner OEM Beige
$105.91
http://www.ncix.com/products/index.php?sku=17413&vpn=DW1655-0B3&am...anufact
BenQ DW1655 Lightscribe DVD+RW16X16X8 DVD-RW16X16X4 CDRW48X48X32 DVD Burner Black W/ SW
$72.69
^comment^ for someone that makes custom albums (as in like just a few every month or season...) is lightsribe worth it? Does it look good/work well? or passing gimmick/stick to traditional sticker labels?
http://www.ncix.com/products/index.php?sku=13912&vpn=ND-3520A&...ufactur
NEC ND-3520A DVD+RW 16X8X16 DVD-RW 16X6X16 Dual LAYER+R 4X INT IDE Beige OEM Burner W/ SW
$69.34
^comment^ put in the extra 10$ instead of the other NEC drive?
http://www.ncix.com/products/index.php?sku=17382&vpn=ND-3550A-SL&a...manufac
NEC ND-3550A DVD+RW 16X8X16X DVD-RW 16X6X16X DL 8X/6X IDE 2MB Burner Silver OEM W/ SW
$59.99
thanks in advance for all your comments. ANY comments are welcome if you see a problem/issue other than the choices i need to make; ie new pats coming out v.soon that i should wait out for etc...
$171.00
which Processor:
$385.02
$460.73
Which mobo?
$256.50
$240.54
$215.86
Memory:
$324.23
IDE Hard Drive:
$210.90
which video card?
$589.39
$578.56
$628.24
$459.89
which Power Supply?
$92.26
$115.24
$192.66
which DVD Writer?
$105.91
$72.69
$69.34
$59.99
