bullion416
I have tried 3 different OS on my computer since I built it. I started with Win Me and it worked fine, except it had problems shutting down b/c it didn't like the fact that I had 5 pci cards plugged in (it would shut down when i removed the ata/100 card, which i was soely using to have every device on its own IDE). Then i switched to Win98 se and that seemed to work the best so far. It shut down, but it kinda lacked performance as far as utalizing new devices and games, etc. So then i switched to Win2k pro. That was in my opinion the best OS i had tried so far, but it ran Unreal tournament and half-life extremely choppy. Also to let you know I have an ATI Radeon 64mb DDR card. I was told by someone else with that same video card that win2k's ACPI does not work well with the card. I was then told to switch it to Standard Pc mode. The opion to switch to standard pc mode was supposed to be in the initial part of the install of win2k and you are supposed to push F6 to get that opion, but i never saw that option. Can you use standard pc mode while using the NTFS (nt file system)? Anyways, I am currently running windows ME again and it is giving me problems with unreal tournament. It just flat out will not install it. You can get to the install screen and when you hit the install button it just freezes up. THIS IS MY QUESTION, WHICH OPERATING SYSTEM SHOULD I USE? ALSO IF YOU KNOW WHAT ANY OF MY PROBLEMS DESCRIBED ABOVE PLEASE GIVE ME SOME ADVICE. THANKS
