- Mar 8, 2005
- 1,623
- 0
- 0
I will be soon building a new computer, and I am starting to research parts starting from my case and cooling devices.
Info on the system (might change a little):
CPU: i7 920 (mild overclock)
Hard Drives: 1SSD, 1 Raptor 150, 3 other 3.5" hard drives
Optical Drives: 1 Blue Ray, 1 DVD-RW
Video: 1 passive cooled card (don't know which one yet), 1 performance card (probably ATI4870, maybe ATI 5850)
Problems: finding the right tower case and CPU cooler to achieve decent temperatures and low noise.
Candidate one: ABS Aplus Black Pearl
Pros:
Cheap (99$ plus shipping), seems well built, has space for future expansion, looks nice.
Cons:
Weird (to me) airflow path, inverted MB (is this an issue?).
The case is shipped with one intake in the lower front (with seemingly quite suffocated positioning) and one intake in the back. Has space for 2 more fans (120) on the top, and 2 more 90 next to the PSU (different compartment).
Doesn't seem quite enough. I see many people in the forums reversing the back 120, and adding 2 more outtake fans on top, going for negative pressure. However, the case having a huge side mesh panel this might mean tons of dust inside the case.
Some people add an intake in the front using a 3-unit fan under the optical drives.
Would one of thiese solutions provide a good airflow inside the case? Being the MB reversed and the fans on top, would it make sense to use an aftermarket cooler for the VGA (blowing towards the top of the case)?
Candidate Two: Lian-Li A-70
Pros: still fairly cheap (~140$), lots of fans in a (to me) very logic path.
Cons: more expensive than the ABS, possibly harder to put cables in a neat way, no side opening at all.
I have never seen the case in person, so I don't know how good/silent/easy to work in this case is.
The fans positioning seems good on paper, but I don't feel experienced enough to really judge this.
CPU Cooler will be either the Corsair H50 (some people love it, some people hate it... opinions on this are appreciated) or an high-end air cooler (Mega, TRUE, other advice on this is appreciated).
Thanks for the precious help...
EDIT: any help in choosing case and CPU cooler fans is also very welcomed...
Pros:
Cons:
