Looking for a mini ITX build that I will be transporting internationally. I will be using an Intel I7 6700K processor, and eventually a GPU like R9 380 probably when prices drop after pascal. Durability , size, and weight are large abnormal considerations that I need to consider, temperatures, features, compatibility also important. Pricing is a tie-breaker more than anything.
I'm Still deciding parts, because I am not positive about the case. Thinking out loud. The case will help put that to a rest!
1. Leaning towards the Thermaltake Core V1 or Thermaltake Surpressor F1 ($48.96) in the pcpartpicker list. Fairly large, can't put in a backpack, but seems great otherwise, durable.
2. Silverstone ML08B-H (Raven RVZ02 w/handle), console size ($83.38), lighter, small issue with not having a 3.5'' hd space, durability is questionable
3. Silverstone Sugo SG13B-Q ($41.41) -
4. Fractal Design node 304 ($92.05) - seems to have heating issues, durability?
5. CM Elite 130 mini-itx ($40.57) - no dust filtering, otherwise seems good
Here is the build:
[PCPartPicker part list](http://pcpartpicker.com/p/k6pXTW) / [Price breakdown by merchant](http://pcpartpicker.com/p/k6pXTW/by_merchant/)
Type|Item|Price
**CPU** | [Intel Core i7-6700K 4.0GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80662i76700k) | $370.80
**CPU Cooler** | [Noctua NH-U9S 46.4 CFM CPU Cooler](http://pcpartpicker.com/part/noctua-cpu-cooler-nhu9s) | $63.00
**Motherboard** | [Asus Z170I PRO GAMING Mini ITX LGA1151 Motherboard](http://pcpartpicker.com/part/asus-motherboard-z170iprogaming) | $159.99 @ SuperBiiz
**Memory** | [Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory](http://pcpartpicker.com/part/corsair-memory-cmk16gx4m2a2400c14r) | $109.00
**Storage** | [Samsung 850 EVO-Series 500GB 2.5" Solid State Drive](http://pcpartpicker.com/part/samsung-internal-hard-drive-mz75e500bam) | Purchased For $0.00
**Storage** | [Toshiba 4TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/toshiba-internal-hard-drive-ph3400u1i72) | $108.00
**Video Card** | [Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card](http://pcpartpicker.com/part/sapphire-video-card-100384nt4goc2l) | $188.98 @ Newegg
**Case** | [Thermaltake Core V1 Mini ITX Tower Case](http://pcpartpicker.com/part/thermaltake-case-ca1b800s1wn00) | $50.07
**Power Supply** | [Silverstone 500W 80+ Gold Certified Fully-Modular SFX Power Supply](http://pcpartpicker.com/part/silverstone-power-supply-sstsx500lg) | $94.99 @ B&H
| **Total** | **$1144.83**
| Generated by [PCPartPicker](http://pcpartpicker.com) 2016-02-22 05:45 EST-0500 |
//notes on part choices and compatibility
**cpu cooler**
Argon AR06 if the Noctua does not fit.
**motherboard**
Asus or MSI z170i pro gaming ($196 / $187) can't decide, MSI is more durable perhaps?
**PSU**
preferrably would fit this PSU in, shown as a "evga supernova g2" on pcpartpicker becuase they do not have super flower, which supplies their better psus
Super flower green FX 500w silver ($59)
** Still deciding parts, because I am not positive about the case. Thinking out loud. The case will help put that to a rest!
Here is the build:
Type|Item|Price
**cpu cooler**
**motherboard**
**PSU**
