Normally I wouldnt say wait a bit BUT with the next generation of Ati cards not far off you might be able to get a much better card in the near future. Take a look at the prices on the Ati X1900XT, right now they are more then you want to spend but if they come down a bit more then it would be a much better choice assuming they fall to your price range. This card will hold you for a LONG time. I am not saying the Nvidias wont but just something to consider. I am sure if the prices were the same as what you are willing to spend most would say get the 1900, now none of this matters if you have to get a card now.
Added a link since this is a good deal
Link
I'm most likely not going to be spending that much for a video card as 370 is way out of my budget even if there's a rebate that brings it down to 270.
As of right now, im leaning towards the evga 7900gt that i posted above for 264.99 with 20 MIR. If anybody has any other suggestions, please let me know. I will be ordering very soon.
30 bucks more for a much better card man, but hey its your dollar and for the resolution you are going to run the other card will do fine. I just wanted you to see other options for a tiny bit more money.
After doing a bit more research, i think i've changed my mind. In the case that i ever buy a monitor >1280x1024, i will be running into serious problems with the 7900gt. Plus, like you said, in the long run, it will only cost me $30 dollars more. The X1900Xt is a wiser investment since it will be more future proof.
That said, i have two X1900Xt video cards that i am considering:
The first is the
SAPPHIRE 100149L Radeon X1900XT 512MB 256-bit GDDR3 VIVO PCI Express x16 Video Card - Retail . It goes for 319.99 plus a 20 MIR which brings it to 289.99.
or the
MSI RX1900XT-VT2D512E Radeon X1900XT 512MB 256-bit GDDR3 VIVO PCI Express x16 Video Card - Retail. It goes for 378.99 but there's a 100 MIR which knocks it to 278.99.
Since both cards will be priced approximately the same after the mail in rebates, my decision will be based on the quality and performance of the card. Which one should i get and does anyone have any experiences with either one of these cards?
Thanks.
