NEED HELP Choosing a Motherboard
hevnsnt
10,868
Hello all..
I recently purchased a FC-PGA Celeron 566 and I am needing a new mobo..
I am upgrading from a *gasp* 233MMX and I am not to familiar with all this "Slocket" and other jargon that goes around with this processor.. (I do understand what a slocket is, but which one do I need?)
I am needing advice on a motherboard, I would like to overclock this sucker, so any advice would be appreciated.
Ausm
14
If you do not plan in buying components frwquently I would go with a Asus P3V4X mobo... It rocks !!
Ausm
IronWood
25
Na, get the GigaByte GA-6VX7-4X. Its a socket 370 board with the Via 133a chipset. No need for any slocket nonsense and it out performs the Asus and more stable too.
Sukhoi
15,350
Yes, but it can be hard to get big heatsinks and fans on FC-PGA motherboards for overclocking. Slockets are only about $20 too.
hevnsnt
10,868
Sukhoi:
I am planning on buying the GigaByte GA-6VX7-4X mentioned earlier.. (guy has them in the for sale forum cheap) Will I be able to put a Golden Orb on this?
hevnsnt
10,868
Also, all I have around here is PC66 Ram (96m worth) am I going to be able to use this ram, or am I going to need to buy PC100-133?
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
I suggest ASUS P3V4X/CUV4X or ASUS CUBX. You should be able to use your existing PC66 RAM with no problems. Even if you overclock to 100MHz FSB, a lot of PC66 can handle 100MHz. Just try it.
hevnsnt
10,868
Thanks for all your help fellas.. BTW this thread pushed me over to Senior Status! Whee.
