Hi, I have $100 in stacked Amazon GCs that I want to use to purchase a firewire card. I found the Adaptec FireConnect 4300 AFW-4300 1394/FireWire Card for $40, some other cards were cheaper but they were of less quality and I'm not sure if they included a cable (software I don't care about).
Is the Adaptec a good card, I went to Adaptec's website and looked at the specs but it didn't say whether this card used a TI chipset, thats the better chipset right?
Also the FAQ for the card said this:
"Q: Can I adjust the DV compression ratio to cram more video onto my hard disk?
No. DV compression is fixed at 5:1."
Does this mean the quality of video I want is limited? Is this controlled by the software or by the card?
Basically I want to know what chipset this card uses, the compression issue, and if you've seen a better deal on Amazon or somewhere else.
Thanks for your help Omar
