Need Help Can't reach over 525@75FSB with Cel 466!!!
CoolCompNerd
4
Got a Gigabyt BX2000 motherboard and that is my problem I can't get on any hihger fsb speed because I can't change the voltage it will only be detected or set automatically and is set at 2.03 and mobo says 2.05 got an Asus slotconverter and wanna know if there is any converter that has the voltage on it and not just the detecting threw the mobo I have a stockHSF on the Cel 466@75FSB(=525)It will start to bootup but not into windows 98
Can anyone give me the website of Soltek I live in The Netherlands, Amsterdam bye the way; Thanx anyway for reeding.:confused:
BlvdKing
1,173
Your lucky you got 75fsb! Celeron 466 are not great overclockers. I think the most you could get even with a voltage mod is 83fsb.
baldy
216
to answer your question regarding the slockets, yes.
MSI has one that will allow for vre adjustments ON the card, others do too. Most of the latest ones will run both the older cellies and the PIII cellies the PIII flippers.
Go here and do some searching.
www.pricewatch.com
Once there, click on Processor Accessories and start looking, the ones you want DON'T sell for $5, but somewhere in the $15 range and up. Once you get a handle on the manufacturers that may offer what you want/need, you then can click yourself directly to the website from pricewatch itself and check the item out. Most will have a section as to where to purchase the item in your neck of the world.
I got my K7V-T shipped in from Australia when they weren't available here in the states, so anything is possible, got the all info I needed from the pricewatch website linkage.
Good luck.
baldy
