I'm writing this on my old pc because my new one won't run.
I had it working pretty good today so I decided to OC. I removed my cpu and unlocked the L1 bridges with a CircuitWriter from Radshak. I re-installed everything and decided to open J17 which is used to set the cpu FSB frequencies from 100MHz to 133MHz. I plugged the system in and blank... it wouldn't put an image on the screen. Then I tried to reboot and it did, but it did nothing. Just the light on the cd drive blinked. I went to shut it off and it wouldn't. I had to pull the plug. I tried closing J17. I turned it on again and blank. I went back after 10 minutes and blank, so I tried to reboot again, and it did. What the heck is going on? Could I have done such a poor job of closing the L1 that the power button is ignored?
K7T Turbo
900MHz Thunderbird
256 pc133 from Crucial
Taisol 742092
Matrox G450 16MB SDR
Win98 2nd Ed
K7T Turbo
900MHz Thunderbird
Taisol 742092
Win98 2nd Ed
