Need help. Can't get display.
I had the computer for a few weeks and it worked perfectly. I never updated any bios as I heard some bad stories about the bios for my mobo, M2N-E, and the computer was working fine so I left it alone. One day I turn the computer on and I don't get any pictures on the monitor. The computer turns on. All fans going. LED light is on. No weird beeps. Just no picture on screen. I try the monitor on another computer and it didn't work either. So I bought a new monitor, same model. That didn't work either. The monitor comes with n analog connector. I had a dvi connector on it. When I remove the dvi connector and plug the monitor in via analog on computer number 2(the comp that doesn't have the M2N-E) in it, it works fine. I reattach the dvi connector on both monitors and the sign on screen that says "Check Signal Cable" goes away. Does this sound like a monitor problem or is there something I can do with the mother board to fix this problem? I emailed this same message to Asus but any input from you guys would be great.
