scoobyx13x
I have this laptop:
http://www.gateway.com/home/products/ret/ret_7330GZ.shtml
P4 3.04ghz, 512mb ram, 80gb hdd.
CPUZ shows that it has 1 512mb stick of pc2700 2.5 CAS Latency in it, as the website says.
Do I have to buy pc2700 speed memory for it to work in my laptop?
Now, the big question:
I want to do photoshop work on this machine while traveling. According to the website, 1.5gb is the most memory that it can support. However, I recall hearing somewhere that mis-matching memory quantities is not good (512+1gb) because it slows the system down. Would I be better off just getting a 512mb stick and putting that in?
I found this stick 1gb stick at Newegg for $108:
http://www.newegg.com/Product/Product.asp?Item=N82E16820145068
and this 512 stick for $42.
http://www.newegg.com/Product/Product.asp?Item=N82E16820221204
Thanks for any help
Thanks for any help
