Need Help Buying a WIRELESS ROUTER
owako
Right now I have linksys wcg200 the worst router ever made btw. I'm looking for a router that can handle download bit-torrents and playing mmo at the same time. I would like a cable modem and router in 1 . But If I have to get a the router on it own I will be fine. Any ideas would be great.
ty
Odds are your torrent usage is starving out your bandwidth for other devices. Unless you're willing to throttle your torrents (with QoS or whatnot), you're basically screwed. I'd first check the router options to see if there's any sort of QoS settings that you can use to prioritize your bandwidth. Again, this is all moot if you're not willing to throttle something.
You absolutely HAVE TO set an upload cap in your torrent program. If you don't it will kill your entire connection. I set mine at 25kbps (or Kbps or whatever) or so and it works great.
