Need help burning Slackware to Cd
EnragedPC
Banned
How do I burn Slackware to 7.1? what are all the files I need? I dont have my burner in yet so can I just save it on my Desktop and burn later or what? and can someone post a link to a fast server where I can d.load everything I need for Slackware 7.1
Here's the slackware download page. Just pick one.
Get Slackware
Look to download a .iso file, that is a CD Image. Then take a program that will burn a .iso, like Easy CD Creator and burn it to CD...
Here's one of the sites that has 3 CD images with a description of each.
The install.iso will have all the files you need and is bootable. the contrib.iso will have extra software and the source.iso is for programmers who want to see the source code.
Sunsite
You only need the install iso. If you have the bandwidth, then you might want the contrib and the other one (cant remember what its called). But you only need the one ISO.
