Originally posted by: kd2777
I have this setup that I like well.
Cooler Master Praetorian Case
EPoX EP-9NDA3+ nF3 Ultra Motherboard
AMD Athlon64 3000+ s939 Winchester Core
Thermalright XP-90 Heatsink
1 GB Corsair pc-3200 cas2.5 Value Select (2*512)
BFG 6800GT OCed version
Antec TRUE430 Power supply
Seagate 120GB HDD
NEC 16x Dual Layer DVD+/-RW
XP Professional
Office 2003
That brings us to 1529.98 right now. You still need a monitor, keyboard, mouse, and possibly a floppy or a media card reader. But this is a good place to start from. There is a lot of places you can cut cost here, but be sure you don?t do it in the wrong places if you are wnating a good gaming rig.
- You can cut a good amount on the case and Power Supply if you fine one you like just as good for less.
- The motherboard and CPU is about as good as you can do for the price because I currently have it running at 2.5 with the cheaper RAM, so leave this the way it is, another choose on the motherboard is the MSI Neo platinum, lots of people like it.
- The heatsink is good investment if you are going to over clock, there are cheaper ones out there that will do a good job, but I have no complaints with this one.
- This memory is great for the cost. I actually use 2GB of this stuff (4*512) but that is actually more than you need. 1GB of this stuff will serve you well.
- The Video card is a good place to cut some cost if you aren?t a huge gamer. A 9800pro at half the cost will give you great results in almost every game but DOOM3. If you are a DOOM player than you might want to stay with the 6800GT.
- The HDD selection is up to you, I use 2 of these Seagate?s, and they are all I need. Some people can get by with 80GB, some with 20GB, and some need 800GB, it depends on the amount of space you need. But I like to stay with Seagate.
- The DVD burner is more of a want for me than a necessity, if you won?t be burning any DVDs than you may want to opt for the CD/RW (I suggest Lite-On).
- An operating system is a must, unless you already have one. You can save a few bucks by going with the home version, but if you are going to be living in a dorm then pro will be preferred.
- Office is another necessity for a college student if you don?t already have it. The one I put in above is the Standard version, there is a pro academic version for 40 bucks more that also includes Access, publisher, and contact manager. It may be worth it to you or not.
This is a good starting point, if this price scares you to death and makes you want to buy an 800 Dell, I would understand. But you said a good gaming rig and this would be that, you can?t compare it to any of the dells except maybe the XPS (but they use the p4 Prescotts and you don?t want one of those!!!).
You may want to check
this Anantech guide out. It has a small budget Gaming rig that comes out to be 750 with out keyboard, mouse, operating system, office, and monitor. You might be able to use their suggested parts and come in at 1500 after the extra stuff.
Good luck
kd
