- Jun 30, 2006
- 15
- 0
- 0
I am trying to put together a system for about $3500, and I have no idea where to start. I am looking at the W5590 but they are expensive at about $1600. I am also looking at the Intel xeon W3580 which is about $600 cheaper. I read that the W5590 is dual socket compatible, while the W3580 is not.
If I can not afford the dual W5590s, are there any advantages to running a single W5590, compared to a single W3580?
Next question, would I be better off running two cheaper processors instead of the single one?
This computer will be used for only 2D, and 3D CAD work.
I figure once I figure out what processor to start with, that will help out building the rest of the system.
One more thing, the price does not include a monitor, I don't need one.
Thanks
Thanks
