Need help and advise for my new PC
fluxs85
Alrite i need some help in between choosing AMD 64 or Pentium 4 E , First at all i use my pc for 3D moddeling purpose, sound editing, video editing, graphic manipulation and other multimedia usage. Other than that i use it to play some games as well.
Below are my both configuration between AMD 64 and Pentium 4 E.
AMD 64 3000+
Asus KV8-X K8T800
512MB Corsair VS DDR400
MSI ATI Radeon 9800 pro
80 GB Seagate 7200cpm 8MB buffer
16x Lite on DVD rom
17" 795MB Samsung monitor
PEntium 4 E 3.0 Ghz
P4p800 SE i865SE
the rest are same as above
I dont overclock my machince and i need a stable pc.... so plz advise me.Thank you
SilentZero
5,158
First thing id so is bump up your memory to 1gb. Secondly, if your going to be doing vid editing and storing video and or large audio file on your pc, space will fill up fast, so it might be a good idea to bump up your storage space also. As far as what processor to go with, I think for the apps your running the P4 would be better than then 3000+. For games, the 3000+ would be better. As much as I like the AMD64, id have to go with the P4 due to the types of apps your planning to run.
fluxs85
So u mean Pentium 4 have a better advantage in graphics and video stuff?
and i heard that AMD64 perform better in 64 bit apllication... will this the usage of the softwares i mention?
SilentZero
5,158
I mean that for things like 3D modeling, video encoding, etc, the P4 3.0 will normally outperform the 3000+. But when it comes to graphics as in playing games, then the 3000+ would be a better choice. But if it were me, and id be primarily doing vid and audio encoding, as well as 3d modeling, id go with the P4 and 1gb of ram. Theres even a few reviews/test articles here on anandtech that give the performance stats on such applications comparing the 3.0 and the 3000+, amongst others.
Pixle
435
You should definetly go with Amd 64's right now. They are cooler and perform better in games and they do compete very well in application (at times outperform intel by a margin).
You will also be able to make a smooth transition to windows longhorn (64bit os.)
thirdlegstump
Banned
Feb 12, 2001
8,713
P4 all the way in your case Flux. Just about every application you'll be running will run quicker on a P4.
