RobsTV,
WetWilly, HUH?????? I did what again?????
I was referring to the
thread where you were making comments on nVidia/Geforce 2D but you were using the
best nVidia cards available and ignoring lots of Geforce cards that really don't have good 2D. As an aside, I had two friends with Geforce2 MXs (Creative) over and asked one of them to bring his card. They both also thought Geforce 2D was very good. Until they saw my V5500. Definite - not minor, not barely noticeable - definite difference in sharpness at 1024x768. The good 'ol nVidia ghosting on the desktop. We won't even discuss 1280x1024. And note the wink next to my initial comment.
as you seem to think only 2 compaines make good TV cards
OK ... tell me who else makes good consumer TV-out video cards with very good-to-excellent TV-out quality and comparable features for setting/tweaking the display that are equivalent to or better than Matrox and ATI. Links to reviews would be appreciated. I'm genuinely interested to know if anyone is using something besides Rockwell/Brooktree/Conexant and Chrontel.
... How can you disagree with this?
Easy. Two reasons. First, image quality. Look at two simplified schematics:
1) Signal generated by video card core -> RAMDAC/TVO conversion to TV-out signal on video card core -> TV-out connector
2) Signal generated by video card core -> RAMDAC -> VGA connector -> VGA-in passthrough on TV-out connector -> Conversion processing VGA-to-TV -> TV-out connector
Which one do you seriously think is going to give you a better display - #1 or #2? #1 is the basic schematic for Matrox's TV-out. #2 is the basic schematic for a scan converter. And like I said before, the Matrox G450 has TV-out
integrated into the G450 core. And what about the VGA passthrough and all the additional cabling the VGA signal gets to go through between your video card and monitor with the scan converter? As we all know from Voodoo/Voodoo2 days, unless you have/had Canopus stuff there's the possibility of a degraded display on your monitor especially at higher resolutions - unless you want to keep disconnecting and reconnecting the scan converter.
Second, NinthKey had a specific use - DVD display. And I'd assume that a sharp display is an issue. So what are his options? Get a scan converter (see #2 above) or for the same cost, a Matrox G450 with DualHead
functions including DVDMax which lets you display full screen DVDs on either a TV or monitor attached to the second head. Plus he upgrades both his regular 2D display and 3D capabilities from the Banshee, and gets the other DualHead stuff as well. For the specific uses he stated, the G450 is a no-brainer.
I also never said anything bad about GeForce2 MX with TV out, and in fact would state just the opposite.
This comment -
I have determined that TV out on a video card is NOT the way to go. which is still in your post as I write this - is the comment I was referring to.
If you insist on getting a card with TV out built-in, (which makes no sense)
See above.
the GeForce2 MX would be one of the best, all around, low cost solutions you can get.
HUH? Solution? Look at the
definition of solution - "the answer to or disposition of a problem." NinthKey's "problem" was a good, low-cost AGP 2x or 4x card to be used primarily for watching movies, and he's not a big gamer. Have you read ANY reviews of TV-out on the MX? Go over to Tom's Hardware
roundup of TwinView MXs. Note the rather consistent comments about colors being off. Oh, and I'll give nVidia the benefit of the doubt and assume they've fixed the problem Tom found that "DVD playback was nearly useless when using TwinView." Specifically, Tom said about his attempts to do DVDMax-like stuff with TwinView:
I was hoping that with these three modes I would be able to do things like work on a spreadsheet for work while a DVD movie played on my second output or play my DVD movie on both outputs. I was denied in both cases.
I would also like to note that while TwinView had failed in my experiments, I had no problems installing a Matrox G400 and completing these tasks. Obviously the G400 isn't in the same class when it comes to 3D performance but its DualHead feature made me realize that TwinView has some growing up to do.
So you're saying that if I'm not a gamer and I want to watch movies on my TV that "one of the best, all around, low cost solutions you can get" is a card with poor TV-out color quality and great 3D benchmarks?
