- Jun 2, 2014
- 94
- 0
- 0
My EVGa GTX 470SC has two 6 pin connectors, now the EVGA GTX 780 has one 6 pin and one 8 pin. My PSU is OCZ 700W GameXtream how I am going to connect it please? because it doesnt have 8 pin connector...
Sounds like you're going to have to buy some adapters or buy a new PSU. You can get a 6 pin PCI-E to 8 pin PCI-E adapter. Buying one of those will allow you to use your card.
Here's a link: http://www.amazon.com/StarTech-Expre...+to+8+pin+pcie
Hi,
thanks very much! So all I need is one adapter? Because only 1 slot needs an 8 pin, the other one is 6 pin, am I right?
It should be enough!
Did you find the power adapters in your GTX 780 box?
